Communication with a Keithley 195A through a Prologix USB-GPIB interface
I would like to interace a laptop with a Keithley 195A (Digital Multimeter).
The only available hardware interface is the GPIB.
On a laptop the available interface is USB.
Than a Prologix USB-GPIB Controller 6.0 device is what should do the job.
Attached there are a sample program from Prologix, a (hopefully) working program for the DMM from Kithley, and what I did (a simple copy and paste).
Result: after running the command ++addr 16, with the program from Prologix (just to start the communication.. I know, I will optimise the program) the program I realised do change the setting of the DMM. Say, I set a Ohm measuring, and the reles switch, but not value is read from the instrument.
What do I miss, or where is the error?
Many thanks
(6,947 Views)
Accepted by topic author Atcold
Solved! Smiley Tongue
The following command was missing:
++auto 1 //Turn on read-after-write and address instrument to talk
Let's now optimise the program! ^^
(6,939 Views)
Here there is the final version! Smiley Happy
(6,931 Views)
I've just got Prologix USB-GPIB adapter and I cant make LV and MAX to find it . Could you help with this?
I have Windows 7 . I have installed  2.08.14 WHQL driver for Prologix  and  NI  488 and VISA drivers.
MAX can not find any device.  although,  Prologix GPIB Configurator communicate with my GPIB instruments OK.
(6,701 Views)
Why would you think MAX should find it? The only thing MAX or LabVIEW is going to find is a new serial port. Installing NI-488 was a waste of time since you are not using an NI 488 controller.
(6,699 Views)
Hello mate!
I aprreciate your answer with your definitive program.
I was doing a program for the Impedance Analyzer HP 4192A and it helped a lot.
(5,174 Views)
