Communicating with Serial Device
Greetings all,
I have a problem with a serial device that I am trying to comunicate with. I have been using hyperterminal to communicate with a serial connected On-Board Diagnostics circuit. The circuit is responding normally using Hyperterminal.
I have tried to implement the "advanced serial read and write" sample code to talk to the device in labview but I recieve the command that I originally sent back as a response. This should not be the case, and I dont know how to rectify it.
Can anybody shed any light on this?
Thanks in advance
(3,580 Views)
First: If it can be done in hyperterminal it can be done in LV using VISA...
common pittfalls:
termination charater: hyperterminal sends a CR/LF when you hit the return key. In LV this needs to be appended (a lot of posts handle this in this forum)
you send the characters to fast to you board: not only a question of baudrate (I assume the settings are equal on both sides). µC sometimes don't have a (big) input buffer. in hyperterm every charater is send when you type it (with your finger delay)
Greetings from Germany
Henrik
LV since v3.1
(3,564 Views)
The knowledge base article you would be looking for can be found here:
http://digital.ni.com/public.nsf/websearch/6C6322FF8F9B790486256D6B0069D281?OpenDocument
I hope this helps!
Kurt
NIUK Applications Engineer
(3,550 Views)
