Chroma AC source
How do I set the phase in Chroma AC source either single or three phase in labVIEW using GPIB? I am able to set the other parameters using the driver except for the proper phase selection..I either need it at single or three phase with phase diff of 120 degrees
(3,330 Views)
Have you changed the other parameters using GPIB commands through LabVIEW? If yes, then there would be some function to adjust phase, if the manufacturer has provided the feature and the same could be achieved using GPIB VIs in LabVIEW.
(3,318 Views)
