Changing GPIB options in the C# program doesn't work
Hi, I'm changing the GPIB primary and secondary addresses using a C# program.
But when I check the values in NI MAX, the values are not the same.
Is there a C# code for confirming settings changes in the GpibInterface class?
Thank you.
(This is part of my code)
(926 Views)
Are you trying to set the address values on your instrument using your C# application?
I don't believe you can do that. You set the instrument address values on the front panel or on dip switches on the back panel on older devices.
Curt
(845 Views)
