09-15-2012
01:02 PM
- last edited on
02-16-2026
01:11 PM
by
Content Cleaner
Hello;
I'm new to Labview, I trying to develop USB drivers using VISA as per the below link..!
http://www.ni.com/white-paper/4478/en; I'm working on the windows 7 OS.
The issue is....: I could create the .INF as directed in web page above; I could not see the .PNF file getting created after right clicking the on the .INF file and select install option..
I don't know whether problem is with OS or the .INF file...
I doubt the OS because It caused me a lot of problems to arrive this point...!
Can any one help me on this Issue...
Thanks in advance...!
Balu...!
09-15-2012 01:25 PM
09-16-2012 02:02 AM
Thanks for the reply..!
I'm trying to interface Logistic webcam (webcam 120) with VID=0x046D and PID=0x080F; I'm attaching the .INF file, Take a look; But I don't know whether it will help you or not..
Thanks..!
09-16-2012 08:15 AM
09-16-2012
08:58 AM
- last edited on
02-16-2026
01:12 PM
by
Content Cleaner
OK.. Let me put it in this way.. My intention is to interface RX62N board with the Labview (in HMI mode) , but as I'm new to Labview; I just thought of implementing the example given by NI( below);interfacing a webcam
http://www.ni.com/white-paper/4478/en#toc2
Yes, You are right I may use the drivers provided by the Logitech, but once I start working with the board which is having with my own code and then if I have a communication problem; I may have to doubt my code or the process I followed to connect to the LabView.
To avoid that conduction I would like to connect the webcam first as per the process given by NI and then proceed with my board..?
09-16-2012 09:40 AM
09-16-2012 11:00 AM
Yes.. You are right, I don't know What to do with the cam once it is connected;
But do I need to follow the same procedure (as mentioned in the above link) to connect my RX62N board to PC using Labview..?
If I'm heading in the wrong direction; can you share some information that will help in to proceed in right direction..!
What is the forum you are talking about..?
Thanks..!
09-16-2012 12:32 PM
09-16-2012 01:54 PM
Thank you for the information;
I think my questions are misguiding you..! my intention is to create a interface using NI VISA USB RAW.
And for that, as per the above mentioned link, i would like to take it as a tutorial and go-throug/complete all the steps mentioned over there.
I don't have any further interest in proceeding with USB Camera interface rather getting acquainted to USB RAW communication through NI VISA.
So, the place i am getting stucked is while creating .PNF file from .INF file.
So, please suggest me or help me in understanding what are the possible reasons for not generating the .PNF file.
I can understand that at this point of time i am not looking at a very broader picture of my project and trying to implementsomething which is there on web. I am aware that i may have to face more problems when i proceed with my board...
I also referred one of your suggestions to refer NUGGET...link below for your ref...
Can you please help me in creating the .PNF file....
Thanks for your time and help....
09-16-2012 02:39 PM
