02-04-2009 10:21 PM
In NI site i found this note regarding the vi that change the VISA buffer size:
""Note Not all serial drivers support user-defined buffer sizes. Therefore, some implementations of VISA might not be able to perform this operation. If an application requires a specific buffer size for performance reasons and the VISA implementation cannot guarantee that size, use some form of handshaking to prevent overflow conditions."
How Can i know if in my application i can change the bufer size?
02-05-2009 04:47 PM
Can you please give me a link to where that quote came from? That will help me track down what it is referring to. VISA is not just used by NI, it is a standard architecture (Virtual Instrument Software Architecture), so that phrase could have a large number of meanings. Thank you!
Mark E.
02-06-2009 01:16 PM
02-06-2009 02:39 PM
The LabVIEW 8.5.1 help is quite extensive. Can you please point me to where you found this quote? Thank you
Mark E.
03:09 PM
- last edited on
06-23-2024
07:28 PM
by
Content Cleaner
I would start looking at set buffersize in the visa menu.
Owning Palette: Serial VIs and Functions
Installed With: Base Package
Sets the size of the I/O buffer. Run the VISA Configure Serial Port VI first if you are setting the size of a serial port buffer.
Note Not all serial drivers support user-defined buffer sizes. Therefore, some implementations of VISA might not be able to perform this operation. If an application requires a specific buffer size for performance reasons and the VISA implementation cannot guarantee that size, use some form of handshaking to prevent overflow conditions. |
