Can Virtual host only ethernet adapter (VM TCP/IP) configured/added using NI VISA ?
I am having an virtual machine (LINUX) debian distribution running in windows 7 host. So it have in default virtual host only adapter of TCP/IP type. ( this can be modified according to the VM network settings : e.g., Bridged Network, NAT, etc).
As per the instrument control using ethernet, the pining have to be done initially before adding or configuring the instrument (in this case Virtual Machine running on the host system connected through virtual ethernet) in NI MAX.
So from the host computer i.e., windos 7 able to ping the Host only ethernet adapter. But while proceeding to the next step of configuring the instrument using NI-MAX were unable to add devices and
(2,640 Views)
attaching the correct images for reference
(2,625 Views)
