Can I find HP 8752A program??
Is there a driver for HP 8752A?
I can only find one for the newer model HP 8753A
I need this for a measurement system.
(3,942 Views)
Unfortunately I was unable to find one either. The command structure "may" be similar enough between the two instruments such that the 8753A will work. If not then you have a couple options. You can submit a request for this driver at:
http://zone.ni.com/idnet/other.htm
We develop drivers based on demand and popularity so the more requests we have for it, the greater the possibility that we will develop one.
If you would like to try developing your own instrument driver (or modify the existing one), we have documentation, model instrument drivers, and driver templates to help at :
http://zone.ni.com/idnet/development.htm).
(3,941 Views)
I have the same problem. is there way to obtain drivers for hp8752a?
(3,765 Views)
Same as Ryan said above, we only have one for the 8752a, and you might be able to use it if the instruments are similar enough. Good luck!
Ebele O.
(3,748 Views)
