Calling VEE from LabVIEW
Does anyone has an example of how to call VEE code from LabVIEW? Thanks.
(3,239 Views)
Hello saf,
If the VEE code can be built into a DLL, then you can call it using the Call Library Function Node (under All Functions->Advanced palette) in LabVIEW. Or if there is an ActiveX interface to VEE, you can use the functions under the All Functions->Communication->ActiveX palette.
Good luck and best regards,
Shakhina P.
(3,215 Views)
