Call Library Function in LabView 6i using a USB interface to U2C-12 USB-I2C/SPI/GPIO Interface Adapter from Diolan.com.
Thank you very much for your help.
I will try to understand your example and then modify to make it works with I2C functions.
VI123
Message 11 of 31
(4,852 Views)
Can you please let me know where can I get general information on how to make the similar work of integrating USB interface adapter with LabView.
I'm using Dimax U2C -12 substitution called SUB-20 SUB-20 Multi Interface USB Adapter.
Message 12 of 31
(4,648 Views)
Znatok,
The previous code posted on this thread is comprised of function calls to a .dll file included with the hardware used.  You will need a driver for the SUB-20 Multi Interface USB Adapter and then you can call the functions that the driver provides using call library function nodes, just like in the other code posted here.
Eric K
Applications Engineering
Message 13 of 31
(4,632 Views)
Message 14 of 31
(4,531 Views)
Here is an example using the U2C-12 with LabView 6i. I hope you find it helpful.
Message 15 of 31
(4,518 Views)
llchu wrote:
I'd love to, but I developed them under my company's nickel, and I don't have the authority/permission to distribute them.
Message 16 of 31
(4,514 Views)
There is a new adapter friom the same company called SUB-20 with  free NI LabView module download
Message 17 of 31
(4,413 Views)
Hi i want to control SPI bus on the Dimax U2C-12 kit using the labview. can any one help in doing so.
Message 18 of 31
(3,998 Views)
Hi. As i wrote already in this forum they (Dimax) have a new compatible device SUB-20 - http://www.xdimax.com/sub20/sub20.html
And for SUB-20 there is a full NI support via .Net component or vi modules for direct DLL calls. Details are here:
http://www.xdimax.com/sub20/sub20.html#DLD
Message 19 of 31
(3,987 Views)
Hello
I am working on Diolan U2C adaptor (I2C to usb), i am already using labview 8.5 with the .dll files, for I2C communication
I came across this forum and you had worked on a the U2C-12 on labview , is it possible for you to share those files... let me know
thanks
vish
Message 20 of 31
(3,484 Views)
