CONNECTING PLC TO LABVIEW
pls what cable do i use to connect labview to telemecanique plc using modbus protocol.
thank you
olisa
(4,060 Views)
Labview is software, and Modbus is a commumications protocol.  What hardware do you have?  What means are you using to communicate?  232? 485? Ethernet?
(4,043 Views)
I want to use RS485 to connect between my PC and the PLC.
thanks you
(4,037 Views)
You haven't said which PLC you have, and since PCs don't typically have 485 ports, you will more than like have to make up your own cable.  Get a pinout for the PLC and for whatever 232 to 485 converter you are going to use.  B&B Electronics has app notes for both Modbus and 422/485 here: http://www.bb-elec.com/tech_articles/rs422_485_app_note/table_of_contents.asp
(4,035 Views)
am using a telemecanique TWDLCAA16DRF, using the modbus adopter.
(4,031 Views)
