C source code drivers for TNT4882
Dear all,
I am new to GPIB. Can anyone give example source code for data transfer from taker to listener for the controller TNT4882?
(4,190 Views)
Hi Bharath,
Thank you for contacting National Instruments.
You can find examples to get started with TNT4882 at the following links-
http://zone.ni.com/devzone/cda/epd/p/id/3272
http://zone.ni.com/devzone/cda/epd/p/id/253
Also you can find additonal material regarding NI TNT4882 at-
https://www.ni.com/en-us/shop/model/tnt4882.html
I hope this is helpful.
Have a great day.
Kanchan Bhakoo
Applications Engineer | National Instruments
(4,183 Views)
I am using theESP software on a PIC Microcontroller, and I am not able to program the Count Registers. I can send to each register individually, and read back the data correctly (i.e. write to R-cnt0, read from Rcnt0 looped 0-255, then repeat for Rcnt1, Rcnt2, Rcnt3 and that works). However, whenever I try to program Rcnt0,Rcnt1,Rcnt2,Rcnt3 in that order, I always read back the value sent to Rcnt3 in all 4 registers??? This is being used in the code to control the count of databytes sent/received in 2's complement.
This is my test code below:
while (1)
  TNT_Out(R_cnt0, 0xAA);
 TNT_Out(R_cnt1, 0x55);
 Delay10KTCYx(200);//Delay 20K cycles
 TNT_Out(R_cnt2, 0xF0);
 TNT_Out(R_cnt3, 0xFF);
 LATD = 0x00;
 TNT_In(R_cnt0);
 LATD = Data_Bus; Reads 0xFF here
 TNT_In(R_cnt1);
 LATD = Data_Bus;Reads 0xFF here
 TNT_In(R_cnt2);
 TNT_In(R_cnt3);
If I reverse Rcnt0 and Rcnt3:
while (1)
  TNT_Out(R_cnt0, 0xFF);
 TNT_Out(R_cnt3, 0xAA);
 LATD = 0x00;
 TNT_In(R_cnt0);
 LATD = Data_Bus; Reads 0xAA here
 TNT_In(R_cnt1);
 LATD = Data_Bus;Reads 0xAA here
 TNT_In(R_cnt2);
 TNT_In(R_cnt3);
(4,137 Views)
Thank you very much..:)
(4,133 Views)
