C++ GPIB Code Too Fast?
I have written some software in Microsoft C++ to send commands to a Wavetek
3600D. When I run the program, none of the commands appear to be written to
the instrument and I get an ENOL error. However when I run the same program
with NI-Spy active, it usually works fine with only an occaisional ENOL
error after sending *RST. It seems to me that the straight program may be
executing too fast for the instrument. Is there a reliable C++ method to
make sure a command is executed before going to the next?
cledus
(4,199 Views)
This is not a problem specific to C++.
In general, some instrument goes bad if you send a lot of
commands at once. How to solve this are normally:
1) Insert "wait" routine between the send commands as need.
2) Insert "query" command and its reading response as need.
This normally makes your instr synchronise command parsing
and internal processing.
Hope this helps
Rai
cledus wrote in message ...
to
program
am may be
>Thanks,
>cledus
(4,199 Views)
