Biodata Microlink 3
I've seen a previous post on this:
> I'm trying to control a 12D-A in a Biodata Microlink 3 (GPIB) without much success. Has anyone managed to control such a device with
> LabView?
> This should be a pretty simple module to get working. The example at ftp://elecmigr.lancs.ac.uk/labview/Microlink12DAexample.vi
> should zero all four channels. Play with the "mode" input to the "Send" node since often the problem is the termination of the command
> string. GPIB cables can also be screwed..
but the link doesn't seem to be working. Again, has anyone got any helpful advice they could give?
Kenneth.
(3,482 Views)
Hi Kenneth,
If I was you I would post onto the original forum posting to see if the person who gave this link can help you, they should still be subscribed to this post so they may see your question.
I've had a look on the NI website and on Google and I can't find a lot of information searching for "Biodata Microlink 3". What are you trying to do with this device? Do you want to program it from LabVIEW - if so then do you have a programmers reference and user manual.
If you can give me some more information about the equipment and what you are trying to do, I might be able to give you some pointers of where to get started.
Regards
Hannah
NIUK & Ireland
(3,463 Views)
OK, cheers. I've posted under that, and I'll await developments!
(3,453 Views)
