06-24-2021 10:00 PM
I need to test a driver developped with LabView for a hardware that I don't have => I plan to develop a test software and to use paired virtual serial ports (created with Eltima Virtual Serial Ports Driver), but I wanted to know first if this works and if these virtual ports will be visible in M&A and writable/readable in LabView.
Thank you.
Solved! Go to Solution.
06-27-2021 09:43 PM
Theoretically, it should work as long as Windows can detect it as a COM port, NI MAX will populate it as Serial port in the VISA control dropdown.
07-03-2021 03:32 AM
Thank you 😊
