Analog Read pin a1 linx
Hi, my name is Francesco
I've already tried to address the Maker hub community but no one answers
How can I tell linx that I use the analogue a1 pin for the thermistor? Because both the pin cable and the attack on pin a1, it always detects me 273.15 degrees
Below I report the photo of the sub vi
I use a 100k ohm resistor
Thank you and sorry for my bad English
(2,876 Views)
Hi
Maybe, just guessing you have to specify 0 (the default for pin 1) otherwise try to find a document that specifically adresses this.
Maybe it also helps to specify more of our systems (pc, labview version,= and hardware system (linx)) used.
Anyway instead of a picture it is preferred to upload a vi
greetings from the Netherlands
(2,862 Views)
Ok Thank you! I'll try this week! Greetings from italy! Next time I'll upload a vi ahah
(2,859 Views)
