Agilent Oscilloscope DSO 2002A
Hi everyone!!
How to measure maximum voltage of channel 1 and channel 2 simultaneously. when I try to do that, both output are showing channel 1 voltage only. could you please help me??
(5,312 Views)
@hariharan1992 wrote:
Hi everyone!!
http://www.keysight.com/owc_discussions/index.jspa?categoryID=1&cc=US&lc=eng
(5,240 Views)
Impossible to say what you've done wrong when you don't provide any details. The most important detail would be showing your code. If you are able to acquire both channels, then the measurements should be easily made with either the built-in scope functions or with the LabVIEW Array Min/Max function.
(5,216 Views)
Here with i have attached my front and block panel of my program.
i have configured two channels separately. my aim is to get maximum voltage of channel 1 and channel 2 separately and channel 1/ channel 2.
(5,182 Views)
