Agilent E3663A VI for constant current mode
Does anyone have the application VI for setting up the constant current mode for Agilent E363X Series Power Supply since I have to set the power supply to run in the constant current mode?
I would be most grateful if you could present me the VI's at your earliest convenience.
Thanks a lot,
James Ouyang
email: xiaohong_ouyang@arxtron.com
Message 1 of 10
(5,752 Views)
It looks like these power supplies (like every other power supply I have ran into) only go into a constant current mode when the current limit is hit.  For instance, if you try to drive 10V into a 10 Ohm resistor with a current limit of 500mA, the supply will go into constant current mode and only supply the 500mA (which comes out to 5V).
If you need something to truely regulate based on current instead of voltage, you really want a Source Meter, like a Keithley 2400 series.
GCentral
Message 2 of 10
(5,750 Views)
Thanks a lot for your valuable information.
Howver, if the current does not reach the limit, it will change with the load.
I am just wondering if there are any VI's which could set up the power supply in constant current mode, as the user manual describes how to set up manually or by programming.
Any suggestion and advice are highly appreciatedf.
James
Message 3 of 10
(5,747 Views)
Just set the voltage to be really high and let the current limit be reached.
GCentral
Message 4 of 10
(5,744 Views)
Good Morning Knight of NI,
Thank you so much for your instruction to set up the current limit. It really works.
Could you tell me if you have the VI to set up the power supply in the constant current mode as described in the user's manual?
Your help and attention are greatly appreciated.
James4711
Message 5 of 10
(5,726 Views)
Could you tell me how I can integrate both Power Supply E3663A VI and DMM 34450 VI into a single VI and run it with power supply set up first then using DMM to measure Voltage?
Thanks a lot,
James4711
Message 6 of 10
(5,725 Views)
I highly recommend you look into the State Machine architecture.  With well defined states, this is super simple.
GCentral
Message 7 of 10
(5,721 Views)
Hi Knight of NI,
Since I am a beginner to use Labview, I am trying in the power supply VI to insert DMM VI but let it run independently. Is that OK? Or you could give better idea.
Thanks a lot,
James
Message 8 of 10
(5,718 Views)
Hi Knight of NI,
I created a blank Main VI but do not know how to insert the power supply vi and dmm vi in the main. Could you please tell me how to do that?
Thanks a lot,
James
Message 9 of 10
(5,716 Views)
It would be easier on all of us if you just took some of the tutorials.
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
GCentral
Message 10 of 10
(5,710 Views)
