Adding a I-V graph to the 'Sweep and Acquire...' Example for Keithley 2401
Please forgive that I am a newbie to labview. I have looked around for an answer but haven't found one that does specifically what I want.
I would like to edit the Keithley 2401 'Sweep and Acquire Measurements' program to output a voltage vs. current graph, as well as outputting an excel file or some sort of readable array of data. I'm honestly not even sure where to start editing the program. I have tried going into the block diagram and replacing the waveform plot with an x-y, but keep getting an error that I have mismatched arrays. Could anybody point me in the right direction?
Thank you,
David
(5,913 Views)
Hi
A waveform graph only needs two arrays and will plot them as function of index.
An xy graph needs a cluster with two arrays the x values and the y values.
If you have measured the current and the voltages you can display this by bundling the x values and y values and connecting the bundle (cluster) to the xy graph.
In the block diagram hover over the xy graph with help open (ctrl-H).
You wil see the way to connect one and more graphs.
By pressing ctrl-space and typing bundle while in the block diagram you can insert the bundle function into the diagram when pressing enter.
greetings from the Netherlands
(5,882 Views)
The example plot either "current vs voltage" as default or if you change the Source mode to Current then it plots "voltage vs. current".  The X and Y labels are wrong and don't change to match what's being plotted.
Here's a quick example of how to get a text file and display arrays of data.
You can drag this image into a LabVIEW VI to test the code.
(5,873 Views)
could you send the VI for keithey 2401 to ,measute voltage vs time and ciurrent vs time
(5,197 Views)
Hello
I'm facing same problem as you posted. I need an I-V curve as well as the data
Could you please send me the latest solution to the IV?
(4,964 Views)
