Acess and calibrate PCI Card on remote computer
I have a question:
I have two computers connected by a crossover ethernet cable. The computer A has Calibration Executive installed and Computer B has a PCI card that i want to calibrate/Acess/Control.
I tried Visa Server but it will only list the devices connected to Computer B by GPIB.
Is there someway that i can connect run Calibration Executive in computer A and calibrate the PCI card inside computer B?
Thanks in advance,
J.S.
(3,907 Views)
Hello jhsilva,
You cannot use a specific computer for calibrating cards which are in an other computer.
You can only calibrate cards in a PXI chassis for example if it's connected through a MXI connection. Otherwise, you must use Calibration Executive on the computer which contains the cards.
Here a document explaining about this topic : How Do I Set Up Hardware for Calibration Executive?
Jérémy C.
NI France
(3,834 Views)
