A strange error when using VISA READ STB function to query status byte.
When I use this function to query the status byte of Standford Research SR830 Lock-in Amplifier,I encounter a strange error.After the function,I use VISA WRITE to query *IDN?.The byte wrriten is 1,not 5 and the read result is wrong.The complete ID is "Stanford_Research_Systems,SR830,s/n76157,ver1.07",but the intrument only deliver "S" for me.If I run the VI again,the number  turnsback to 5 and the result is right now.Then run again,it turns to 1 again,and then 5 back....But if I use VISA WRITE to send "*STB?",everything is normal.I am quite confused.In addtion,if I use VISA CLEAR function,the error also emerge.
Do you ever encounter such problem?
(3,988 Views)
This is difficult to diagnose without seeing your code, but I would guess that you are telling the function to only receive 1 byte of data from the instrument.  Look at the parameters for the method, one of them may be the number of bytes to read, if you only put a "1", you will only read 1 byte (converted to character, you get one "S" returned, the first character of the ID).
Post the part of your code you are using for further analysis.
(3,870 Views)
My previous post also explains why the "*STB?" query completes as it should.  Whe you read the status byte, you are only reading 1 byte, so if you are requesting 1 byte, it completes without error.
(3,868 Views)
