A problem with programmatically changing plot names.
I am trying to programmatically change plot names using "active plot" and "plot->name" property nodes. However, every time I run my program, the names toggle between the programmatic names and the task names specified by the DAQ assistant. Can someone help me? I will attach my code in case anybody wants to take a look.
Thank You
(3,269 Views)
Molana,
I believe this is a repeat post and the other post has been answered...but just to make sure you get a good answer I would like to see your code. A very small piece of your code that does nothing but demonstrate the issue you are talking about please.
Brett
(3,253 Views)
