8756A locks up after read
I've been working with the HP 8756A and have been having problems with it locking up after performing a read function.
After entering command 'OD' and reading all 401 points, "Data Dump" appears on the screen.From this point on I can not send any command or retrieve any data.
When I use “OI” command for identification, HP 8756A locked up again!!!
I have attached the program to call for and retrieve the data in case it is in my programming.
Thanks for any help
Message 1 of 12
(4,697 Views)
Are these driver VIs or did you write them yourself?
What does the programming manual say are command syntax?
Message 2 of 12
(4,681 Views)
NI doesn’t have any driver for it and I couldn’t find a driver that is compatible with 8756A Network analyzer. So I writed my VISA driver. I attached the operation manual of 8756A Network analyzer; there is the programming manual at 57 page of it
Message 3 of 12
(4,673 Views)
Are you able to use VISA Interactive to communicate with the instrument?
This removes the unknown of your LabVIEW VIs.
This is a very old instrument, you might also want to look into NI-488 instead of VISA.
Message 4 of 12
(4,649 Views)
I don’t know that this instrument supports VISA or not. But I did configuration setting on this instrument by “VISA write” and also I could do to force instrument to Reset.
I used “VISA open” to set VISA resource name to “GPIB1::19::INSTR”. Only, I have been having problems with it locking up after performing a read function.
So this instrument supports VISA, Is it true?
Message 5 of 12
(4,637 Views)
here.pngVISA will not be a problem.  but with old old old HP-IB you need to tweak some VISA session properties (untalk and unlisten for starters)
"Should be" isn't "Is" -Jay
Message 6 of 12
(4,620 Views)
I can not find terminal port on your image. I put “property node” on VI and added 6 properties, but I could not find the port which connected to “TermChar property”.
Please guide me to find it on function palette.
I attached the new Initialize.vi.
Thank you.
Message 7 of 12
(4,608 Views)
That is the Type Cast function.  The point of it is to change the string character into a U8.  It can be found in the Numeric->Data Manipulation palette.
GCentral
Message 8 of 12
(4,602 Views)
Thank you.
That is a Snippet not an image.  you can drop it on a blank block diagram and RUN itSmiley Surprised with LabVIEW 2012
Message 9 of 12
(4,598 Views)
Hello Jeff,
Would you mind posting the snippet in an older version of LabVIEW (possibly 2009) for the benefit of others who will read this discussion forum?
Shawn S. | NIC
Instrument Driver/IVI PSE
Message 10 of 12
(4,586 Views)
