4145B Reading Problems
Hi all,
I am wokring on 4145B, using Labview and the Example vi from Henry.  I am getting progress but now I am stuck with the reading part.  I saw that some people ran into the similar problem.  And Henry gave a solution by delaying.  What I have  here is a little bit different.
Since I can find the very first set of data in the object .txt file, which means it is reading data from 4145B, but not all just one set.  I can see a bunch of sets on the 4145B screen, but only the first set in the objected .txt file.
Can anybody give me a hand here?  Thanks.
Chris
(3,577 Views)
Accepted by topic author Chris_Li
Hi all,
I figured out this problem.  In Henry' example,  at third stage of the time seq
 uence loop, the input to one block(in the middle, i don't know how to call it), it was ;  But it should be N
which is the seperating symble of the data array.  I don't if this is depending on my 4145B data format. And if it is working for everybody else, then that is because of my specific case.
Chris.
(3,570 Views)
