3D surface graph
Hi Guys,I'm trying to draw a 3D graph. I have set the Range of the X, Y and Z-matrix axis as auto scaling. But the graph is looking in a different way. For an example, if the X-axis in the range of 440mm-540mm with 10mm iteration. The output graph is not clear and the points are not widely spread on the
X-axis. I have attached my VI with this post. Could anyone help me please?
 Mayuren
(3,612 Views)
Hi Mayuren,
Hope you are well.
I have made alterations to the VI you posted, so that the axes of the Graph will be changed dynamically based on the maximum and minimum values of the arrays being passed to it.
I would also recommend having a look through some of the examples in the LabVIEW Example finder (shown in attached jpeg file).
Best Regards,
Steve
(3,578 Views)
