16902A Agilent Logic Analyzer
I have a 16902A Agilent Logic Analyzer and would like to control it via LabVIEW.
However, I could not find any drivers for it.
Is there any way I can control it by LabVIEW ?
(5,479 Views)
It has the following ports.
  • LAN: 10/100 BaseT (optional Gbit LAN) E5860A Gbit LAN Card
  • I/O Ports: Two USB 1.1, parallel, serial,
Look forward to your help.
Raghu
(5,461 Views)
What does the manual or agilent say about remote control? Are those ports used to connect to a pc or connecting to a network or storage devices?
(5,453 Views)
Connect the LA thru ethernet and Use NI VISA to connect to it. You need to install setupLAcom.exe that can be find on your LA's computer C drive or probably on Aglent's website. setupLAcom.exe provides necessary ActiveX controls that you can use in LV to actually control your VISA connected LA. That's how I do it. Hope it works out for you.
(5,446 Views)
Acccording to the FAQ this device is programmable via its COM interface out of the box .You can use Labview to do that. Examples should be available in the Help.
(5,430 Views)
