-1073807342 error
I have been controlling a Keysight Power Supply device using NI VISA in LabVIEW  .It was working fine . I sent queries using MAX and after sometime I tried to control it again using the LabVIEW program and it sent me the error -1073807342 . I tried it multiple times and still not able to fix it . What should I be doing ?
Thanks in advance
(4,985 Views)
You can't control your instrument with both MAX and your LabVIEW program.  Close out the MAX interface before running your program.  You may need to shut down LabVIEW to make sure all of its references are cleared out.
(4,983 Views)
