Industrial Communications
Why one modbus device (PLC) has two address (Slave)
Hello, I'm new modbus. I try to study modbus application in LabVIEW by one example (Other person developed but now I can not contact to ask these question). The example code as bellow:
Modbus code
The device I want to communicate is PLC (TSXP57 103 Schneider) through PCMCIA 114 card and one converter from 485 to RS232.
I don't understand why in this code has two Acquision modbus.VI with two different Slave addresss (1 and 2 as above code). What is slave address I need to configure for my PLC (1 or 2)? Because I see only one PLC in this system.
The block diagram of Acquisition as bellow
As above blok diagram, I understand that LabVIEW will read input register from start address 500 with 45 register. This my understand is correct? If yes, PLC program need to store it's data at address %MW500 or %MW30500 (Because the register address of  "Read Input Registers" command from 30001-39999 as my understand)
Please tell me what is wrong in my understading!
Thank you
What is INO Measure?
Please find the answer at www.ino.com.vn site!
(7,523 Views)
Accepted by topic author ino_measure
Greetings ino measure.
If I understand your application correctly, I believe you should be setting the slave address to 1.  If you would like to learn more about this modbus implementation in LabVIEW, I highly recommend visiting the link below as that article covers the use of this particular library.  Hope this helps!
Introduction to MODBUS
Michael G
Michael G.
Self-realization: I was thinking of the immortal words of Socrates, who said, "... I drank what?"
(7,501 Views)
Hi Michael G,
Thank for your reply. My problem come from a misunderstand. The diagram code I posted was written for system with two PLCs. They modified hardware system but not yet finish modified software. After study and test on the hardware, I already solved the trouble. You are right, I should set up the address to 1 and delete one of them (Only one PLC on new system).
Thank for your help.
(7,496 Views)
