04-01-2013 03:08 PM
Hello all,
I have an application where I need my host PC to receive a simple message from a PLC via Profibus. I will be using LabVIEW on the host PC. The message will only be about 20 bytes and there will be a new message every 5 seconds or so.
As you can see, the throughput is pretty low. Are there any low cost solutions for Profibus interfaces that would suit my needs?
04-01-2013
03:59 PM
- last edited on
03-25-2025
10:05 AM
by
Content Cleaner
Hi vt,
We have a PCI card that we sell here. I that is your cheapest best bet. There is a PXI and cRIO solution if needed also.
04-01-2013 04:18 PM
Thanks, Jesse. All things being equal, I certainly would prefer NI products. I was hoping to find something < $500.
04-01-2013 05:39 PM
Sorry vt,
I don't think we have anything that low. The next best option is getting a third party card and calling it's driver API from LV. I have seen cards for $600. You would just need to build up the API between the two.
If your PLC can act as a profibus master, you could configure your PC as a slave and use a Profibus to serial converter to convert to RS 232. Then the PC could use Modbus or serial to communicate to the profibus network. However, I would make sure you have plenty of time to implement a system like that. People I worked with in the past needed a lot of time to get things working after messing with the physical layer of profibus.
04-16-2013 12:00 PM
04-17-2013
09:06 AM
- last edited on
03-25-2025
10:04 AM
by
Content Cleaner
Hey indiana,
Can you expound on this solution? I have heard people talk about it but haven't seen it implemented yet. Would it use the DSC opc servers? if so which one?
Thanks.
