Industrial Communications
Problem with memory leak in modbus library
 Excellent stuff, I have now tried to implement this and I think it is working :). I will run some tests over the holidays.
Some last things, I found out I had to take av the inlining of the subvi to be allowed to add a delete data value referance, I guess that is the way to do it?
Also is this something you will share with R&D and mabye smithd ( the creator of the library i linked to before). Seems to me this fix is relativly simple and should be implementet both in the labs-version and the official library?
Thanks again and happy holidays.
Mrmas
Message 11 of 12
(1,127 Views)
Glad everything seems to be working for you. The CAR you linked earlier has the same information attached internally so R&D is aware of this. I didn't want to bother Smithd because he went to work elsewhere but our systems engineering team owns the labs version and I let them know about it as well.
Happy Holidays.
Message 12 of 12
(1,122 Views)
