Industrial Communications
NI RS 232 COMMUNICATION WITH VOSTCH VT 4002ECM
In this page:
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Is-there-an-instrument-driver-for-Heraeus-V%...
was the advice which helped us with VT4002. Somebody wrote:
"I had problems with VT 4010, the problem was only that in the user manual was not write the wiring of RS232  25Pin to 9Pin.
The wiring is the following:
25Pin  -->  9Pin
2 --->  2
3--->   3
7--->  7      (NOT 2 with 3 and viceversa)."
Changing TX and RX using soldering iron in DB25 helped
Message 11 of 15
(2,359 Views)
Hi Zarrar,
I was using the labview to control VT4002,Can U help to give some advice to control it,
Give me the VIs or the ASCII string
Message 12 of 15
(2,333 Views)
I m able to communicate with the climatic chamber, i.e that i can read the temperature, I can also set the temperature, but i'm not able via the ASCII 2 protocole to start the climatic chamber ? Could you confirm me if it is possible with the RS232 connection or if I have to use the digital IO to do it.
Thank you very much !
Message 13 of 15
(2,078 Views)
Hello, I have also come across this problem with a HC 4120 chamber. I can set and read the temperatures but I haven't found a way to start the chamber using the RS-232 ASCII 2 protocol.
Have you found a solution to the problem yet?
Message 14 of 15
(1,832 Views)
Hi Zarrar,
I see this is long back for your but i am just working on the same equipment can you share the cable informations which you used in the figure09in the zipfile and which pin are used for the communication
and can you share the succeded file in communication so it can be a helpful for me as a beginner
Message 15 of 15
(566 Views)
