Industrial Communications
Is it possible to connect interface multiple Profinet based Siemens PLC in once cpu?
I have an application where i have to interface with multiple siemens 1200 based plc(Profinet ).in single cpu.
I want to monitor different Memory bits in PLC at every 100 ms.Earlier I had done interfacing with single plc but never i had done with multiple plc at same time.
Looking forward for feedback/suggestions from you guys
(3,657 Views)
Is the PLC acting as a PROFINET master or PROFINET slave?
What other hardware do you have (e.g. what is on the other side of the cable)?
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,558 Views)
