Industrial Communications
Interface honeywell hc-900 with LabVIEW and and control the hybrid controller using LabVIEW from a remote location
Hi
For a uni project i want to interface honeywell hybrid control HC-900 (C30) controller for a process control e.g, temperature with LabVIEW and upload the data to cloud or any web server. Then from a remote location access the uploaded data and use labVIEW to control and monitor the process.
I am new to the controller and LabVIEW, thus need your suggestion and advice on the implementation of the idea.
The hc-900 process controller support open Ethernet connectivity, for in detail communication protocols open the below link
http://fluidic-ltd.co.uk/product/honeywell-hc900/
Also Matrikon OPC server is available.
Your kind feedback and suggestions will be much appreciated.
Syed
(3,930 Views)
Hey Syed,
I've had a quick look for you but I couldn't find any helpful examples for the Honeywell HC-900 (C30). For a broad overview I'd look into :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3gXCAQ&l=en-US
It might also be helpful to know there is a free OPC client by Matrikon OPC Explorer. You can then interact with OPC through LabVIEW through Datasocket or shared variables: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MwxSAE&l=en-US
Good luck with your project!
Rebecca
(3,899 Views)
Syed,
I second what Rebecca posted. I think you'll need to dig in the HC-900's manuals to see how 'open ethernet' translates into actual data exchanged and over what protocol (e.g. TCP, UDP, etc).
From the page you linked: "Serial Modbus connectivity using selectable Modbus RTU capability, allows RS232 and/or RS485 ports to be configured as Modbus slaves, while one of the ports is selected as a Modbus master."
If you computer has a serial port (which are generally RS 232), you can leverage LabVIEW's connectivity with modbus to communicate with the device.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,893 Views)
