03-08-2013 03:37 AM
I have profibus board installed in a PC.
the pc doesn't have labview installed. only testStand.
purpose of this PC is as test panel for running test cases in TestStand and this PC will be connected to I/O.
how possible can i test the profibus if there's no Labview installed?
Solved! Go to Solution.
03-08-2013 04:22 AM
Please use COMSOFT Configurator tool if you are using NI-PCI Profibus card.
If you have used the right GSD files with proper electrical wiring, once you deploy the configured bus,you should get all okay(green) status. Any error in device GSD file or electrical connection will be indicated in red.
Even you can Set\Reset selected bits individually.
03-11-2013 07:54 PM
All of the LED are OFF.
03-11-2013 08:37 PM
ok sorry...actually ALL Led of the profibus card are ON.
at the moment the connection is like this:
controller (sim as the machine) -> CAN -> getaway -> PC (with profibus card installed)
where can i get the gsd file?
please refer to the attachment
03-11-2013 11:23 PM
The vendor of your device should provide you the GSD file. Each device supporting profibus usually come with a GSD file.
03-12-2013 12:19 AM
Ok noted.
Yes already successfully configured & communicated well.
03-12-2013 12:27 AM
Cool. Good luck with the bit level manipulation in the next stage.
