Industrial Communications
Error on Open DeviceNet IO.vi
I'm getting the following error every time I try to run my project (please see attachment "DeviceNET error.png"). Since it seems to have lost part of a library, I went to MAX and on to Add or Remove software to make sure that all drivers and libraries (especially that of device net) are present. However, I get the error seen in attached image "MAX DeviceNet Error". I also tried to reinstall the the industrial communication's device net drivers 2.2, but when I do, it doesn't install or remove anything. I'm guessing that the installer believes that it's all there.
Could someone help me with this?
All the best,
Jose
(5,740 Views)
Hi Jose,
Since you have another post with the same question, organization and efficiency purposes, let's keep the discussion contained there.
Thank you
Tarek B
(5,724 Views)
