06-30-2010 02:23 AM
I have a DF Profi II board that I want to set as master and a I have two slave devices(D-MAX). I have with me the input -output mapping (D-Max gateway instruction manual)for the slave devices. I want to set the slaves using the Configurator II. Please send any information you have about the procedure to set the input-output map in the configuration.I am attaching the D-Max gateway instruction. Suggestions are appreciated.
Thank you
11-03-2010 10:12 AM
From the manual it looks like your drive is EthernetIP instead of profibus what the PROFI II board can do? Am I wrong?
11-08-2010 08:58 PM
Hi Mr.Dirk
I am sorry for the delayed response. I am attaching another gateway instruction manual. Please check and let me know if this will work. If it does work can please instruct me on how to use it on the profibus?. Thank you.
regards,
ganesh
