IF-RIO
java virtual machine error!!
Hi!
I have a problem with java virtual machine. When I compile an FPGA VI, with memory resource inside, at the beginning of compilation I see this Error:
"Regenerating IP..."
"Error occurred during initialization of Vnot reserve enough space for object heanot create the Java virtual machineFinished Regenerating"
Then, labview doesn't create ngc file of memory object.
(6,069 Views)
What exactly are you referring to when you say "memory resource"?  Are you referring to the Memory Read and Memory Write VIs?  My first guess would be that the Java Virtual Machine does not have enough memory to perform a compilation on your VI.  Have you tried compiling this same VI on another machine?  Also, could you post a screenshot of the actual error message?  Any additional information would be helpful, thanks!
(6,044 Views)
Hi!
I resolved the problem.. I have reistalled Windows XP, and Labview...
Thanks for all...
(5,999 Views)
