Hobbyist Toolkit
Juami potentiostat - Arduino code error after LINX Firmware flash
Hi, I have Arduino uno 3 and I am working on assembling JUAMI Potentiostat.
I installed latest LabVIew - comunity edition (btw. it is still asking for licence)
I did firmware flash via: Hobbyist > Firmware wizzard.
The example with blink LED was working.
Then i tried to run this code (from JUAMI potentiostat project) via Arduino IDE,but i have error, can you help me please ?
code:
#include <SPI.h>
#include <Wire.h>
#include <EEPROM.h>
#include <Servo.h>
#include <LinxArduinoUno.h>
#include <LinxSerialListener.h>
LinxArduinoUno* LinxDevice;
void setup()
LinxDevice = new LinxArduinoUno();
LinxSerialConnection.Start(LinxDevice, 0);
TCCR1B =B00000001;
void loop()
LinxSerialConnection.CheckForCommands();
and i haveSnímka obrazovky 2024-06-06 095702.png this error:
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\Lukas\AppData\Local\Temp\arduino\sketches\9BFF2B109BABF543B1979459E0B61E31\sketch\sketch_jun6a.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
C:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src C:\Users\Lukas\AppData\Local\Temp\arduino\sketches\9BFF2B109BABF543B1979459E0B61E31\sketch\sketch_jun6a.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
C:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\Lukas\AppData\Local\Temp\arduino\sketches\9BFF2B109BABF543B1979459E0B61E31\sketch\sketch_jun6a.ino.cpp -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
C:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src C:\Users\Lukas\AppData\Local\Temp\arduino\sketches\9BFF2B109BABF543B1979459E0B61E31\sketch\sketch_jun6a.ino.cpp -o nul
Alternatives for Servo.h: [Servo@1.2.1]
ResolveLibrary(Servo.h)
-> candidates: [Servo@1.2.1]
C:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\Lukas\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src -IC:\Users\Lukas\AppData\Local\Arduino15\libraries\Servo\src C:\Users\Lukas\AppData\Local\Temp\arduino\sketches\9BFF2B109BABF543B1979459E0B61E31\sketch\sketch_jun6a.ino.cpp -o nul
C:\Users\Lukas\AppData\Local\Temp\.arduinoIDE-unsaved202456-20432-6qmyre.mjgi5\sketch_jun6a\sketch_jun6a.ino:5:10: fatal error: LinxArduinoUno.h: No such file or directory
compilation terminated.
Alternatives for LinxArduinoUno.h: []
ResolveLibrary(LinxArduinoUno.h)
-> candidates: []
exit status 1
Compilation error: LinxArduinoUno.h: No such file or directory
Message 1 of 1
(807 Views)
