High-Speed Digitizers
unable to display waveform / multiple recording
Hi I am Ratnam .I am currently doing a project on Heart Sound . I acquired signal using Ni usB6008 continuously.Now i want to calculate the Heart Rate using Auto correlation.Is it possible to use it calculate heart soundOr is three any better function that i cud use
 Thank you
Message 11 of 16
(4,609 Views)
You really should start a new thread with this question.
The answer to your question is "Yes." You can calculate heart rate using autocorrelation.  Depending upon how fast you want an update (every beat, every ten beats) and what you want the delay to be, (none, ten seconds, etc.) it may be easier to use a fourier transform based method.  If you give a bit more information about what problem you are trying to solve, we can be more helpful.  LabVIEW contains a huge number of analysis routines.  You can usually solve any one problem at least three or four different, valid ways.  The best way will be determined by what you are trying to do.
Message 12 of 16
(4,590 Views)
Hi .Thanks for ur reply.I have created a program to read the heart sound  frm the NI USB 6008.Is it possible for you to check whether I cud calculate Heart rate using Auto correalation.
I wud be happy if u cud troubleshoot my program .Thanks
Message 13 of 16
(4,566 Views)
Hi DFGrey, Thanks for ur help.I have to submit this project by this week.Is it possible for you to troubleshoot my program .I  donot know how to use auto correlation .Thus i would be very glad if you cud help me
Message 14 of 16
(4,262 Views)
I have started a new thread for this topic so it will get the proper visibility. Please go to help on autocorrelation.
Message 15 of 16
(4,248 Views)
OOPS. Bad link. Try this one - help on autocorrelation.
Message 16 of 16
(4,243 Views)
