High-Speed Digitizers
buffer for continuous acquisition
I have a PXI-5124 board.I need to perform a continuous acquisition for a signal (frequency at 1MHz,cycle time is 10s).i set the min sampling rate as 5MHz,the min record length as 50Ms.i store the data into the file. I use the queue as a buffer ,but the result is not satisfying. when I run the digitizer for a while, every time it indicated “the memory is not enough”. May I ask the board can satisfy the physical need? how should I set the buffer?
Message 1 of 1
(5,700 Views)
