High-Speed Digitizers
USB-5133 Input circuit
Hi.
Is it possible to get schematic of analog input circuit for USB-5133? Thanks.
(3,077 Views)
Hi Valentin87,
Precise schematics are generally classified as NI Confidential.  Here is some public information which may help you:
https://www.ni.com/documentation/en/oscilloscope-device/latest/usb-5133/overview/
  • 40 mVpk-pk to 40 Vpk-pk input range
  • 1 MΩ input impedance
  • AC, DC and GND coupling
https://www.ni.com/documentation/en/oscilloscope-device/latest/usb-5133/block-diagram/
GUID-AAD006DA-C780-49B6-8DA6-9D32A4B3BCC6-5.5x8.5%20-%20a5
Sorry that this is maybe an oversimplified answer to your request.
If you can be more specific in your questions about the input circuit, I may be able to provide some more detailed answers.
(3,031 Views)
The spec additionally tells :
Input impedance 1MOhm || ~17pf
AC cutoff 12 Hz (3db) ...
Hook up a NVA and you can measure all properties you migth need 😉
However a bit more documentation as can be found in other digitizer/scope devices from NI should be standard!
Greetings from Germany
Henrik
LV since v3.1
(3,008 Views)
