High-Speed Digitizers
Simultaneous Sampling between multiple WIFI cards (i.e.. NI 9239 Measurement system)
I'd like to build a multichannel acquisition system. A hard requirement is that all channel should be sampled simultaneous (used for beamforming). To avoid a lot of cabling the WIFI modules (i.e.. NI 9239 Measurement system) seem ideal. To spread the sensors out in a room I'd like to use multiple of these modules, but I need them to sample on the same clock (a clock delay isn't such a problem, but different clock jitter is --> glitches). For as far as I checked the datasheet of the NI 9239 (and similar), I think this can't be done...
Other needed specs are:
- # analog in: min 4
- FSmin = 16000Hz
- inputtype = voltage (for microphones)
- inputrange: preferably -1 --> 1V
So I wonder if there are any other similar products (using WIFI and sample simultaneous.) for which this is a possibility? Or am I mistaken and is it possible with the  NI 9239 (and similar)?
Thanks in advance!
Greetz,
Bert
(5,781 Views)
Hello Bert,
At this moment the NI 9191 doesn't have external PFI lines for triggering and sharing the hardware clock.
Could you please contact our office NI Belgium: 02/7570020 so we can further discuss your project?
Thanks!
Nico
(5,762 Views)
