High-Speed Digitizers
Reading time for fetching Multiple Records vs Single Record
Hi Andrew,
I change from one channel to two channels and it worked well, I read all the records in about 80-90 ms, I didn't have time to try the Example that you mention but I will try it on Monday.
Thank you very much Andrew, even that know I will be reading half of the samples because I am reading both channels it is still 5 or 6 times faster.
Rodrigo Cuenca
www.cidesi.com
Message 11 of 13
(3,517 Views)
Hi Rodrigo,
Will you have an opportunity to test with Configured Acquisition and confirm those results as well?
-Andrew
Message 12 of 13
(3,510 Views)
Hi Andrew,
I modified the Configured Aquisition Example to read more than 1 record, and it was the same, so I start the VI with one channel and it was like 1300ms, I started the VI with two channels and it was like 70 ms, but when I started the VI with two channels and then while running I changed to just one channel it worked well it was the same as the two channels, I don't know why.
Rodrigo Cuenca
www.cidesi.com
Message 13 of 13
(3,502 Views)
