High-Speed Digitizers
Problem about "niScope_configureclock"
Hello :
      (1)
         I am a new user of NI 5114. My project was used the card to sample the waveform data by different sample rate.
         But now  I have problem about changing the sample clock source frome on board  to the  extenal clock in using the SMB connector(100MHz).
         When I append  the  c code in GenericFetchForever.c of NI example, the return value=1. Anyone can help me to fix the problem.
         My append c code : checkErr(niScope_ConfigureClock(*vi,NISCOPE_VAL_CLK_IN,
        NISCOPE_VAL_NO_SOURCE,
        NISCOPE_VAL_FALSE));
                                         error=1 , the card report "Initilize failed".
        What happend in this card??
      (2)
            Another question is how to use the parameter of divided N to change different sample rate.
            When i checked the card data sheet,It said that sample rate divide by n decimation available where 1 ≤ n ≤ 65,535.
            Did any function use the N decimaiton to control the sample rate?
            I fond two parameter about  sampel clock source and n decimation,"NISCOPE_ATTR_INPUT_CLOCK_SOURCE"," NISCOPE_ATTR_SAMP_CLK_TIMEBASE_DIV".
            But i didnt know how to use it to change sample rate.
            on board clock source I used minSampelrate to configure  : niScope_ConfigureHorizontalTiming (*vi, minSampleRate,
        minRecordLength,
        refPosition, numRecords,
        enforceRealtime));
           But now in external CLK_IN how to configure or setup the sameple rate ? still used this function or used n decimation ?
           Thanks for your help.
Message 1 of 1
(6,381 Views)
