High-Speed Digitizers
PXIe-5624 Support in LabVIEW 2016 and Newer Versions
Hi All
We use LabVIEW 2018 and have a PXIe-5624.
I know the latest version of "NI LabVIEW Instrument Design Libraries for IF Digitizers" is only 2015
and found the following discussion thread.
https://forums.ni.com/t5/LabVIEW/NI-LabVIEW-Instrument-Design-Libraries-for-IF-Digitizers-15-0/td-p/...
It seems the original poster installed the library in 2015 and manually copied it into LV2017 as the workaround.  However, in LabVIEW 2018, even opening the 5624 bitfile generated in LV2015 by open FPGA reference leads to error.  Is there any way to program 5624 in newer LabVIEW version than 2018?  We have other NI hardware that is only supported  in newer LabVIEW version.
Thank you
(2,547 Views)
Accepted by topic author vincent.lai@tctechinc.com
(2,513 Views)
