High-Speed Digitizers
PXI-5105 rms accuracy
What is the accuracy of a rms value on a PXI-5105 ? The only specifications you get is the AC Amplitude Accuracy and the RMS noise.
(6,276 Views)
Hey bartvsc,
If you look at page 5 on the PXI/PCI-5105 Specifications Document:
http://www.ni.com/pdf/manuals/374403g.pdf
You will see that depending on the Vpk-pk and input impedance range you will get a different AC Amplitude Accuracy. You can get the RMS Accuracy value by calculating it from the AC amplitude accuracy.
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(6,231 Views)
How do you calculate the rms accuracy from the AC amplitude accuracy ?
(6,214 Views)
