High-Speed Digitizers
NI PCI 5102 installation issues
Hello jebeyers,
 How does your device show up in the Windows Device Manager?  Does it show up with a yellow exclamation point?  Did you receive any errors from Windows or National Instruments?
Here is a KnowledgeBase that describes why your computers BIOS might not be updated.  Do you have another computer that you can try the PCI-5102 in?
Respectfully,
Rob F
Test Engineer
Condition Measurements
Message 11 of 17
(6,069 Views)
I have installed this card in another PC and the test panel worked correctly.
Per the knowledge base article, I update the computers BIOs and installed the linked patch.  Netiher fixed the problem.
The device shows up in Windows Device Manger, under Data Aquisition Devices and windows states the device is working properly.  The driver is listed as 2.1.0F1, but when I look in MAX the driver listed under installed software is 3.4.0F3.  Should these numbers match?
Message 12 of 17
(6,061 Views)
Hello  jebeyers,
What computer did the 5102 work on?  Can you give more specifics about the HP DX2200?  What motherboard is being used by that computer?  What are the exact specifications of the computer?
Can you try uninstall the driver for the 5102 in Device Manager, then restart your computer?  (Right-click on the device and select uninstall)
Respectfully,
Rob F
Test Engineer
Message 13 of 17
(6,045 Views)
I untinstalled the 5102 in the device manager and restarted the computer.  Windows detected the hardware, but the problem still exists.
The computer the card worked on had the following specs:
Manufacturer Hewlett-Packard
Product Name HP d220 MT (DG266A)
Machine Type AT/AT COMPATIBLE
Manufacturer Lite-On Tech.
Model 0888h
Chipset Vendor Intel Corporation
Chipset Model 845G/GL/GE Brookdale Host-Hub Interface Bridge (B1-step)
&CPU Intel Pentium 4
Number of CPU(s) One Physical Processor / One Core / One Logical Processor
Vendor GenuineIntel
CPU Full Name Intel Pentium 4
CPU Name Intel(R) Pentium(R) 4 CPU 2.40GHz
The computer the card fails in has the following specs:
Product Name HP Compaq dx2200 MT
Manufacturer MSI
Model 0A48
Chipset Vendor ATI Technologies Inc
Chipset Model RS400/200 Host Bridge
&CPU Intel Pentium 4 HT
Number of CPU(s) One Physical Processor / One Core / 2 Logical Processors / 64 bits
Vendor GenuineIntel
CPU Full Name Intel Pentium 4 HT
CPU Name Intel(R) Pentium(R) 4 CPU 3.06GHz
Message 14 of 17
(6,040 Views)
I dont know if this is the correct thread, but here is a sub issue of installing a 5102 board. I recently upgraded my software to the latest NI-Scope and driver versions. The Soft Front Panel works as expected. However when I attempt to access the board via C++, the simplist of tasks (autosetup) doesnt find the active signal on either channel. Any suggestions?
Message 15 of 17
(6,025 Views)
Hello Jebeyers,
Some motherboards require weird restrictions for PCI boards.  The problem is not in the chipset  or in the speed of the processer.  Unfortunately, it sounds like there might be an incompatibility between our 5102 and your motherboard.  Usually updating the BIOS will fix this problem.  However, it seems that updating the BIOS will not fix this problem.
Is there any reason why the computer cannot be utilized for your application?
Respectfully,
Rob F
Test Engineer
Message 16 of 17
(5,986 Views)
Hi Paul,
Looks like you found an answer to your question on the thread found here.  If you could keep your questions regarding your issue to that thread, it will help keep our boards more organized for future readers.
Paul C.
Message 17 of 17
(5,971 Views)
