LabVIEW7.0 is not officially supported on windows seven. But you can also make the test to be sure if it's works or not.
Regards
Yann C.
France
I have an application which runs, and should reveive data input via a serial input (COM1). No data is received. A control with a terminal program like "Teraterm" shows that the serial port functions OK. I have not tried to port the application to a later version of LAbview. The application functions perfectly on Windows XP.
Hello everyone,
You can find some information about LabVIEW/OS compatibility on the following link.
http://www.ni.com/labview/os-support/f/
Sabri JATLAOUI
Here's a link not uselesS with LabVIEW 7.
Best regards.
Dear JBMW,
As the previous link said. No.
Best regards.
