High-Speed Digitizers
Absolute vs RMS Reading on Two Different Scopes
I am encountering a problem where the same NI-SCOPE based code is resulting in two different amplitude readings from different digitizers. The signal in question is a 3.3V PPS Square Wave signal. A 5114 correctly outputs 3.3V amplitude, however a 5170 outputs 2.2V. The only thing I can think of is that the 5170 is defaulting to Vrms. Thoughts? Attached is the code.
(3,554 Views)
Check this information out:
- Calculating Absolute Accuracy or System Accuracy - https://www.ni.com/en/support/documentation/supplemental/18/calculating-absolute-accuracy-or-system-...
Natalia Cubillo
Applications Engineering
(3,535 Views)
