Hardware Developers Community - NI sbRIO & SOM
Cannot get any SOM examples working...
I have the SOM and Reference Carrier board and cannot get any of the "Getting Started" examples to work.
When I try to run the "Read On-Board Temperatures" example is get the following deployment errors:
Deploying sbRIO-9651 Read On-Board Temperatures (RT).visbRIO-9651 Read On-Board Temperatures (RT).vi loaded with errors on the target and was closed.
LabVIEW:  Failed to load shared library nisyscfg.*:nisyscfg_lv_sysapiPropertySetUnsignedInteger:C          . Ensure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer custom libraries to the RT target.
LabVIEW:  Failed to load shared library nisyscfg.*:nisyscfg_lv_sysapiPropertyGetStringIndexed:C          . Ensure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer custom libraries to the RT target.
LabVIEW:  Failed to load shared library nisyscfg.*:nisyscfg_lv_sysapiPropertyGetDoubleIndexed:C          . Ensure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer custom libraries to the RT target.
Deployment completed with errors
I have done the 2015 SP1 updates on the SOM, RT and installed LV14 SP1, FPGA, Xilinx and Real-Time updates. (I had the error before the updates and was told to update all the software)
SOM firmware 2.2.0
NI CompactRIO 14.5 - February 2015
CompactRIO Support 14.5
LabVIEW Real-Time 14.0.1
NI System Configuration Remote Support 14.5.0
NI-RIO 14.5
Run-Time Engine for Web Services 14.5.0
SSL Support for LabVIEW RT 14.5.0
WebDAV Server 14.0.0
Available add-ons:
DataSocket for LabVIEW Real-Time 5.2.0
EPICS Client I/O Server 14.0.0
EPICS Server I/O Server 14.0.0
HTTP Client with SSL Support 14.0.0
Hardware Configuration Web Support 14.5.0
I/O Variable Remote Configuration Web Service 1.3
LabVIEW Control Design and Simulation 14.0
Language Support for Japanese 14.0.1
Language Support for Simplified Chinese 14.0.1
Legacy FTP Server (deprecated) 1.3.0
Modbus I/O Server 14.0.0
NI Application Web Server 14.5.0
NI Scan Engine 4.3
NI System Configuration 14.5.0
NI Vision RT 14.5.0
NI Web-based Configuration and Monitoring 14.0.0
NI Wireless Certificate Management Web Service 1.2
NI-Embedded CAN for RIO 14.0.0
NI-IMAQdx 14.5.0
NI-Industrial Communications for EtherNet/IP 14.0.0
NI-RIO IO Scan 14.5
NI-VISA 14.0.0
NI-VISA ENET Passport 14.0.0
NI-VISA ENET-ASRL Passport 14.0.0
NI-VISA Remote Passport 14.0.0
NI-VISA Server 14.0.0
NI-VISA USB Passport 14.0.0
NI-Watchdog 14.1.0
Network Configuration Web Support 14.5.0
Network Streams 14.0
Network Variable Engine 14.0.0
OPC UA Client API 14.0.1
OPC UA Server API 14.0.1
Remote Panel Server for LabVIEW RT 14.5.0
SMTP Client with SSL Support 14.5.0
Software Management Web Support 14.5.0
System State Publisher 3.3.0
Time Configuration Web Support 14.0.0
USB3 Vision Support 14.5.0
Variable Client Support for LabVIEW RT 14.0.0
Variable Legacy Protocol Support 5.6.0
Variable Legacy Server Support 5.6.0
Variable Web Service 14.0.0
WebDAV Client with SSL Support 14.0.0
Unavailable add-ons:
NI-Industrial Communications for EtherCAT 14.5 (not available on host)
NI-TimeSync Plugin for Software-Based 1588 14.5.0 (not available on host)
LabVIEW SoftMotion Module 14.1.0 (older version available on host
(7,273 Views)
I was able to resolve the problem by doing the following:
1. Format the SOM system.
2. Re-install the base software as shown here:
Now I can run the Read Temp RT example and at this point (Xilinx compiling in the background...) the FPGA example seems to be linking correctly.
Regards
Jack Hamilton
PS: I will post more on this forum as we develop on the SOM, very exciting system!.
(5,552 Views)
Hi Jack,
I am glad you were able to resolve this issue. I don't see any noticeable differences in the software support you chose. Those errors are generally linked to not have the NI System Configuration Suipport installed. However, it looks like you did from the screenshot above.
- Tanner
Tannerite
(5,552 Views)
I am runnning the EPICS IO server on a CRIO 9068 and the EPICS IO client on my PC.  The update rate is about 2Hz.  I'm curious if you are having the same update rate or is it unique to my system?
Christiana
(5,552 Views)
Hi Christiana,
This community is driven towards sbRIO hardware development. I think you would receive the best results by posting to the LabVIEW DSC NI Forums.
- Tanner
Tannerite
(5,552 Views)
